creating a shape like twisted soft serve twirl
I'm trying to create a shape that looks like a Mr. Softee twirl sitting on top of a half sphere. I've tried sweeping a cirlcular shape around a helix and having that sit on top of the half sphere...however when I go to core it out, the whole part kind of blows up (I guess due to the sweep not really having a solid form within the "twirl")....
Can anyone direct me as to how to creat this configuration... I will need to core the finished shape to .080 wall.
Thanks in advance for your suggestions.
John
RE: creating a shape like twisted soft serve twirl
You're probably on the right track with a sweep.  Perhaps add a guide curve or two to control your section better.  Use a point with a pierce constraint to relate your section to path and guide curves.
You may need to do this piecemeal with surfaces and stich it together afterward --OR-- have your section sketch be two concentric circles.
I would suggest trying to create a few cross sections then loft the shape.
Good Luck.
Try extruding a big block on top of your sphere.  Then create a helix inside of it, sweep a cut around your helix then use Offset Surface to create your shelled Mr. Softee.  I was able to do a very crude undefined version of that, I had some issues at the top of the twirl but I think with a little massage you can get it to achieve what you desire.
Fill what's empty. Empty what's full. And scratch where it itches.
Thanks for the suggestions.  I did wind up with the method suggested by aamorso.... there's a bit of piecing and stitching.... but I think that'll work.  Thanks all for your suggestions.
In 2005 you can do "flex", twisting/bending/stretching parts. If you have 05, give it a try.
Chris
Sr. Mechanical Designer, CAD
SolidWorks 05 SP1.1 / PDMWorks 05
ctopher's home site
