Save Toolbar Location
Hi, I'm working in Solidworks 2005 in dual screen mode...tried to setup/position my toolbars on my second screen the way I want them. If I close an assembly or part file without closing Solidworks, then I reopen any part or assembly file...my toolbars stay intact, but as soon as I close Solidworks and start it again all of the toolbars loose the position I had given them...and are all one on top of each other. Is there a way to save my toolbars positions so I don't need to ajuste them every time?
Thx
Colombo75
Thx
Colombo75
RE: Save Toolbar Location
Flores
Chris
Sr. Mechanical Designer, CAD
SolidWorks 05 SP1.1 / PDMWorks 05
ctopher's home site
I knew that "part, assembly and drawing files save their own toolbar locations" that what I tried and I get the result mentionned above.....
If SW isn't shut down after positionning them, then the floating toolbar stay at the right place.....but if SW is shut down then restarted it looses the locations.
Colombo75
Chris
ctopher's home site
I don't think that doing a "repair" will do the trick, we are 7 SW2005SP2 users in my office and we all have the same problem, I believe it's a SW programming problem.
Like I mentionned above, if SW ISN'T closed than the toolbars stay, if it's closed than they need to be repositionned.
Colombo75
Not being able to write to the registry could cause this problem.
Flores
Fill what's empty. Empty what's full. And scratch where it itches.
I have Administrative rights.
I'm asking myself....if it's the fact that my mane SW window is on 1 screen and I but all my floating toolbars on my second screen???
Colombo75
Does your card supprt dual-mon with SW?
Chris
ctopher's home site
I have a Nvidia Quadro 750XGL also and running dual monitor....no problem exept this toolbar issue
colombo75
Chris
ctopher's home site
