Rotating An Assy In Animator?
How do rotate an assy about a certain point that I define when I'm using animator?
Printed Circuit Board Designer
Salt Lake City, Utah
No Substitute for american muscle !
RE: Rotating An Assy In Animator?
However if you need to rotate about a specific point the easiest thing to do is create a 3D sketch making a centerline coincident to that point and either vertical, horizontal,or along Z. Then rotate about that sketch using the method discussed above.
Best Regards,
Jon
Challenges are what makes life interesting; overcoming them is what makes life meaningful.
Solidworks 2005 SP2.0
Scott Baugh, CSWP
3DVision Technologies
www.3dvisiontech.com
www.scottjbaugh.com
FAQ731-376
FAQ559-716 - SW Fora Users
ht
You can rotate about the model X, Y, and Z axis, or a combination of the axi. Also you can tell it how many rotation increments, as well as save each rotation to a jpeg ((to make animations).
Flores
