exporting from UG/Manager
When exporting from NX2 using Tools->UG/Manager->export I can add a suffix to the file name. This would make it handy when exporting assemblies because I could add a database attribute to the file name. Is it possible to make the string a varible?
We are using Teamcenter to handle the NX files.
RE: exporting from UG/Manager
I am not sure you will be able to do this from NX interface, but you can try it from the the utiliy "export...", refer to NXMANAGER help and you will lean more on the mapping file that the export utility refer to.
