multiple selection sets
I select all of the lines on a certain layer. I then want to cycle through those lines and select above those lines to see if there is text that goes along with each line.
I need two selection sets and to be able to step through the one (For each LineObj in objSS) and then to be able to have another selection set to select the text.
How do I switch back and forth between the two?
RE: multiple selection sets
"Everybody is ignorant, only on different subjects." — Will Rogers
