433 MHz flat antenna design
Our product (www.designatedparking.com) is a 20" aluminum partially spherical housing 3" tall with a 4" plastic canopy under which the antenna lies. We use a spiral antenna with estimated gain of -14dbD, and the range is only 40 feet with a -112 db receiver. We need at least twice that range.
We are looking for an improved antenna concept. Thanks for any help.
RE: 433 MHz flat antenna design
Where are you aiming your current "14dBd" antenna? If it really does have that much gain (that's a lot by the way), then is it aimed in the general direction of the car?
How did you decide where the car would be ? 40 or 80 feet away, the client could be over there or over here. This application calls out for a low gain antenna to provide better coverage.
Why not put the antenna, a better antenna, into the nice yellow and black plastic gate?
Does the driver need to see the gate?
IR R/C might be a better choice.
Why 80' ? Is the motor too slow ?
The range requirement is 25 feet from inside the car. That cuts 6 to 10 db off the power, so we are now in the 45-80 feet line of sight range. Any closer and you can not see the barrier over the nose of your car.
We can not put out a vertical antenna due to vandalism. Placing the antenna in the horizontal barrier will not do much good when the barrier is down, and anyways it will be surrounded by metal.
Garage door openers can typically do at least 100' and they often use a cheap superregeneratiev receiver and a dangling wire antenna.
You are right -- the antenna stinks. So... what can you suggest?
dori@dp-corp.com
Once you get the system working to maximum range, then you'll see how much margin you have.
One would think that you could use a simple bit of wire bent into the plastic part of the housing.
1) At what frequency is your product?
2) What is the "package" and transmit antenna on the user end? - A Garage Door Opener package?
3) Could your your link-margin problem on the transmitter end? (I find it hard to believe your antenna is as bad as -14 dBm
4) Don't you have some additional problems locating the antenna in the base when it rains and water may cover it by an inch or two?
Suggestions-
Yes, you can put your antenna inside the aluminum cross-bar depending upon the frequency. I assume your cross-bar is extruded, therefore hollow. If the antenna is put in the crossbar, and a slot 1/4 wavelength long is milled through the bar, it will radiate. The slot can be coverved by a tough plastic. At this point, it depends upon: frequency, location inside the bar, spacing, etc. Some cleaver mechanical design to feed a coax from your receiver up through the hinge joints to the antenna will be needed.
Alternate antenna suggestion - create a larger slot in the crossbar plugged with plastic, and mount the antenna in the middle of the plastic flush with the outside. You can color the plastic and make it look like it is part of the styling.
Size is approx. 7" long, 3" wide, and 0.063" thick. It gives wide beamwidth and will have about 15 dB more gain than your present antenna and it's vertically polarized (even though it's flat). Material cost is $1.17 per antenna from McMaster Carr ($35 for a 24x36 inch piece). Assembly is simple.
It's also tough enough to drive over it.
What's your signal frequency bandwidth (and source frequency stability/drift) and temperature range?
kch
Antenna Engineer)
Toyon Research Corporation).
Feel free to call me with questions, (805)685-1482.
Teflon works better with about -1 to -3dBi gain, depending on whether you use a full sized patch (1/2-wavelength in the dielectric) or a half-patch (1/4-wavelength in the dielectric).
If you can afford exotic materials, TMM4 (Rogers) or Arlon are also well suited to patch antennas in this band. Loss tangents for these materials are 10 times better than for FR4 or about 0.001 but the reduced size due to the higher dielectric constant reduces antenna gain by another 1-2dB compared to Teflon.
Tuning tends to be fairly narrow at 434MHz as well so that detuning effects due to dirt, oil, rain or other items on the antenna will further reduce gain due to the off tuned condition.
The patch should be made of 0.125" thick material to provide maximum performance (i.e., >0.01-wavelength thick).
The best performance would be an Air dielectric patch but the size would increase significantly to about 14" diameter (or per side) and spacing of 1/2-inch or more would be required. There would be mechanical design issues, as well, such as keeping water out of the structure, having a struture strong enough to drive over, and support of the radiating plate over the ground plane.
I made an antenna for Dori using FR4. The gain was alot higher than -8 dBi, closer to zero dBi. I can't discuss the details of the antenna design other than saying that FR4 varies alot and is not a well controlled/tested dielectric.
It's in production now.
kch
I think that our company can help you. We are designing different kind of antennas including remote keyless entry hidden planar antennas for automotive applications (passive and active). Antenna is printed on circuit board with or without amplifier.
I assume (see fave quote) that the device gets power from someware... Do a central or distributed receiver system from the power distro point.
Fave Quote... Never Assume, You make an Ass out of U and Me
kch
Dori
Good to hear it's what you needed. I've been thinking of starting my own company "www.FastAntennas.com", but haven't done it yet. There are alot of designs such as yours that take very little effort.
kch
