33kV Indoor Vacuum Circuit Breaker Epoxy Cast Resin Material Info Rqd.
Hello
I hope somebody can help me with this, I can't seem to find the correct information anywhere. I'm currently looking an option of designing a indoor 33kV vacuum circuit breaker and I have been told that the circuit breaker housing will be made from epoxy cast resin. I do not know exactly what type of epoxy resin it should be and it would useful to know the correct (or most common) material so as I can investigate its properties further.
Any help on this would be much appreciated.
Stephen
Stephen
