Pressure Vessel Discharge Time
I am trying to calculate the amount of time it will take compressed air to discharge from a pressure vessel through an orifice.
Here are the varibles.
Vessel volume at 14.7 PSI: 11.52 cubic feet
Filled Pressure: 120 PSI
Volume of compressed air at 120 PSI: 94.04 cubic feet
Orifice Diameter: 3.75"
I originally calculated the amount of flow through a 3.75" orifice at 120 PSI. Then I determined the time by the amount of flow and vessel volume. I am having second thoughts about this because the flow is not constant as the vessel is discharging. The volume and pressure is decreasing which I believe would affect the discharge time.
Anyone have any thoughts or suggestions on this?
Casey
RE: Pressure Vessel Discharge Time
Thanks Rich, that was the information I was looking for.
What is this calculation for?  I looked at it (briefly) with a spreadsheet I have and got something in the order of less than 1/2 a second.
I didn't dig into the details but total volume of compressed air in the receiver at 120psig receiver pressure is 105.56 cu.ft at 14.7 psia pressure.
