saltwater vertical pumps
any idea about what are the best materials to use for each component of a vertical saltwater pump?
Thank you so much
RE: saltwater vertical pumps
a lot will depend on the pump size, the duty, the life required from the unit and how much money you have to spend. materials could range from el-cheapo cast iron all the way through to monel.
Naresuan University
Phitsanulok
Thailand
