looking for a specific grade of aluminum - anticorodal-100
i am working for a european scientist who requires
a grade of aluminum only found in europe. the material
is anticorodal-100. the composition, i think, is AlMgSil.
do you have a material with these specifications? i need
two rounds, 6" dia. x 1" thick.
i've been informed that this material is called 6063 here
in the u.s. and it is an extruded material only. so now
i'm looking for tube shapes, 6" o.d. x 1" wall, and
4.5" o.d. x 1" wall
kenn fasanella
kenn@research.nj.nec.com
RE: looking for a specific grade of aluminum - anticorodal-100
Yes, there is a standard for aluminum known as C.C2.100 in Yugoslavia, and its equivalent in the U.S would be 6063, known as the
