Seeking micro air motor 1/8 to 1/3hp 3500 rpm
I am seeking a very small air motor or someone to design same for a new product I am working on.
1/6 to 1/3 hp output (0.125 to 0.25 Kw) 3250 rpm approx.
Dimensions
diameter approx. 1.1 inches 28mm
length approx. 2.0 inches 51mm
Even if someone can point me in the right direction it will be a big help.
Dimensions
RE: Seeking micro air motor 1/8 to 1/3hp 3500 rpm
For starters try Parker Hannifin Corporation - Actuator Division. Their catalog shows a 0.47 ft.lb.torque, 3600 RPM, 1.06 OD x 5 long unit. I think these are vane type motors with a concentric or coaxial planetary gear reduction unit. The output shaft dia. is 0.312. I have not found any in your torque speed range with overall length less than 5. Another source may be ARO Ingersoll Rand.
McMaster Carr has several in the size range you are looking for in thier catalog.
