Crude Tank Inertization
Anybody have experience with the inertization of crude cone-roof tanks when the diameter exceeds certain diameter.
I need to design a coneroof tank, and according some legal requirement, when the product storaged in this kind of tank is crude, and the diameter exceeds 50 m, then is mandatory to install an inert gas system (let say nitrogen).
I would like to know if this is a normal requirement or there is a mistake?
If this is reasonable, would be necessary the installation of a foam system?
Thanks.
Thanks.
RE: Crude Tank Inertization
I never seen such big tanks with blanketing.
You should go ahead with internal or external floating roof.
