Added Text in Dimensions (Drawing)
I'm creating a drawing with dimensions used to create the model. Here is my problem - I click on the dimension then in the property manager I add 2X<DIM> to signify I want two of those please. Then I will go do something else within SWx. Then come back to the drawing and bam that added text is back to just the dimension <DIM>. I just upgraded to 2005 from 2003 so is this a new problem or a setting I'm not aware existed. Thanks
Best Regards,
Heckler
Sr. Mechanical Engineer
SW2005 SP 2.0 & Pro/E 2001
Dell Precision 370
P4 3.6 GHz, 1GB RAM
XP Pro SP2.0
NIVIDA Quadro FX 1400
Do you trust your intuition or go with the flow?
RE: Added Text in Dimensions (Drawing)
Also, even though the 2X goes away, does it show up in PRINT PREVIEW or when printing?
I do not have this problem.
Chris
Sr. Mechanical Designer, CAD
SolidWorks 05 SP1.1 / PDMWorks 05
ctopher's home site
See Thread559-90842 for how to change the setting.
If I use the Smart Dimension tool, then I can add a prefix or suffix (2X or O.D. for example) and if I change the model, the prefix or suffix stays put.
Flores
Thanks OLID for that thread....a star for you
Best Regards,
Heckler
Dell Precision 370
P4 3.6 GHz, 1GB RAM
XP Pro SP2.0
Chris
ctopher's home site
FAQ559-930
Scott Baugh, CSWP
3DVision Technologies
www.3dvisiontech.com
www.scottjbaugh.com
FAQ731-376
FAQ559-716 - SW Fora Users
I have a question - Why would SWx want the user to go into Regedit to change a variable? I just think it would be more user friendly if SWx had something like Pro/e 2001 a user config file that variables could be set or overridden. I'm not sure SWx intended for their user base to hack into regedit to set a variable. Correct me if I'm wrong here but SWx still sells itself on bi-directionality between part - assembly - drawing, correct? Just a thought while I'm trying to wake up.
Best Regards,
Heckler
Dell Precision 370
P4 3.6 GHz, 1GB RAM
XP Pro SP2.0
Flores
