ISO 2678 QUERY
ISO 2678 QUERY
Hi Guys,
I understand that ISO 2768-1 is a tolerancing standard for 'linear & angular dimensions'.
Why doesn't it cover radial and diameterical (spelling?) dimensions?
What standard should be referred to for radial dimensions?
Many thanks,
Andy.
RE: ISO 2678 QUERY
ISO 2768-2, Geometrical tolerances for features without individual tolerance indications
What do you mean by "radial and diameterical dimesnions?"
ISO 2768-2 covers flatness, straightness, circularity, cylindricity, perpendicularity, symmetry, coaxiality, and circular run-out.
These are your form features that don't require datums and orientations that usually only reference one datum.
"Fixed in the next release" should replace "Product First" as the PTC slogan.
Ben Loosli
CAD/CAM System Analyst
Ingersoll-Rand
RE: ISO 2678 QUERY
What do you mean by "radial and diameterical dimensions?"
Well ISO-2678 relates to linear and angular dimensions. What if I have a circular bar with a diameter that I want to tolerance to the same standard?
The diameter dimension is not a linear dimension is it?
Andy.
RE: ISO 2678 QUERY
Ben Loosli
Ingersoll-Rand
RE: ISO 2678 QUERY
Fill what's empty. Empty what's full. And scratch where it itches.
