Storage modulus
Storage modulus
Storage modulus
Is it possible to determine a value for Young's modulus from a material's storage modulus?
I believe the storage modulus is determined from a dynamic test. I have a static application I wish to consider but only have storage modulus info for the material.
RE: Storage modulus
E = stress/strain
Devise a simple supported beam, and derive E from the deflection formula under a known load.
RE: Storage modulus
Bulk Modulus (E*) is also a good approximation, but requires you to know the Loss Modulus (E") in addition to the Storage Modulus (E').
Since E* = E' + iE",
E* can be calculated by:
E* = SQRT( (E')^2 + (E")^2  )
