Acad 2000 to 2004/05 conversion issues
This is a reiteration of an older post. Still having the same problem. We still use acad 2000 (Upper management decision) but have some seats of acad 2005 for working with customer files that have been saved as such. When we open a 2000 dwg in '05 we get a warning that it was made in an educational file. This is not so!
No part of the file was made in an educational file but it was made in 2000. Also there are no xref's that may cause this problem.
If I take a file erase everthing, cut all links and save as new file I will still get this warning.
My vendor has been little help, and Adesk doesn't help. Any ideas? The guys at DWG Gateway (www.dwggateway.com/index.html) are looking into it also.
RE: Acad 2000 to 2004/05 conversion issues
it translates correctly? It is an obvious bug
in the software.
Seems to be an issue between 2000 and 2005. I erased everything and purged the file, saved as a new file, and it would still give a warning regardless of version saved to.
In the end, I have proven that there is no way the file was edited or contained files made in an Educational version. Thanks for the help.
