Sweep Profile Question
I am having a problem creating a tubular steel part. The front profile is a 90 degree arc with a 20" radius. The top profile starts horizontal with a 3" radius to an incline of 20 degrees at about the mid point of the arc. Any suggestions are appreciated.
RE: Sweep Profile Question
Create sketch for dia, then a 3Dsketch for profile. Then sweep. You can do shell after the sweep.
Chris
Sr. Mechanical Designer, CAD
SolidWorks 05 SP1.1 / PDMWorks 05
ctopher's home site
My main problem is not being able to create a 3d sketch of this profile. I'm using 2003 version which doesn't allow arcs in 3d sketches. I have tried a few methods but can't create the profile I want.
Thank you
Harold
You should be able to go back into the 3D sketch in SW03 and radius/fillet the sketch corners to get your arcs.
"I think there is a world market for maybe five computers."
Thomas Watson, chairman of IBM, 1943.
Have you read FAQ731-376 to make the best use of Eng-Tips Forums?
I do not remember if this can be done in SW2003.  Did you try a Projected Curve?
Regg
Projected curves have been around since Early SW... like around SW99 or earlier.
There is a thread in this forum on using a Projected curve that I posted in here to a user and that worked for him. I can't find the thread here now though?
Scott Baugh, CSWP
3DVision Technologies
www.3dvisiontech.com
www.scottjbaugh.com
FAQ731-376
FAQ559-716 - SW Fora Users
