Checking Hardness of Nitrided 4140/4340 Parts
Can anyone recommend a testing method for nitrided parts? The tester our QC is using is a Hartip 3000, and we seem to always get lower values than expected. It is possible to 'break through' the case and read a lower value than actually present? The case depth is supposed to be >.015". Also, generally how hard a case can you expect with these matrials?
RE: Checking Hardness of Nitrided 4140/4340 Parts
As you note - on thin cases it is very easy to affect the apparent surface hardness if you try to test directly on the part and start to deform the substrate material.
With regards to nitriding, a microhardness traverse is definitely the way to go. You want to measure both hardness and depth. Knoop or Vickers with an indentation load of 0.025-0.050 kgf is best, with the indentations at least 3 diagonals apart. As swall mentioned, the hardness will likely be 62 HRC maximum (~ 750 HV or ~ 775 HK).
Nitrex has a nice description of this type of testing in Issue 25 (September 2003, page 3) of their newsletter called Nitrex Communicator. Use the following link to obtain more information:
http://www.nitrex.com/library_archives.ch2
http://www.nitrex.com/iactivefiles/Nwsl026.pdf
http://www.nitrex.com/iactivefiles/Nwsl025.pdf
Cory
You gave up an old trade secret of the metallurgical technician. I was shown this trick by my boss in about my third week on the job in 1952. I could even do the math. Used it many, many times.
Another one you can do if the part will allow it is to zig-zag, offset each reading.
