Coating test for Galvanneal
I need a test that my warehouse people can do in the plant to distinguish between galvanized and galvanneal. We use copper sulfate to identify zinc coatings, but it doesn't tell between galvanized and galvanneal very well. Is there another way to test for galvanneal that can be done on the plant floor?
Vince
Vince
RE: Coating test for Galvanneal
Galvaneal sheets are dull gray in appearance and have no spangle.
I would contact your supplier if you require chem testing or another more sufficient need.
Fill what's empty. Empty what's full. And scratch where it itches.
Proper material tagging and lot control helps, though your application may not specifically require it.
For a nominal cost you could have your materials service center run a coloured line (red, blue, green) down the center or ink-jet the ASTM# every foot or so.
regards,
Hydroformer
