Gear design based on max holding force?
I am designing a pinion and gear to be used in a design project that I am working on. I am having an issue with the maximum torque being applied on the pinion and gear. I I was just wondering if someone knows how I would go about solving for a maximum holding force rather then operational rotational force. I know how to design the pinion and gear based on when it is moving but I don't need it to be moving for my max design load.
Anyone have any ideas?
RE: Gear design based on max holding force?
operating load as the maximum load and
1.4 for the max operating loads.
It does depend on your application however.
W = S b Y
where
W = Max load Pounds
S = Max allowable stress (Usually 40% UTS)
or UTS divided by the Safety Factor
for that conditional load.
b = gear face width
Y = Lewis Y factor (based on the number of teeth
of a complete 360 degree gear)
The pinion will normally be the weakest member
unless you go to a modified tooth form and then
also use a stronger material for it.
I have an excell spread sheet with the Y factor
if you need it for normal, 25 percent long, and
50 percent long addendum gears and pinions and
20 degree pressure angles.
