Hygienic 3-way control valve required
Dear all,
I need a food grade (hygienic) 3-way control valve. So to Split ONE flow in TWO flows; 0 - 100% adjustable.
Can you suggest some good manufacturers? Types?
Many thanks for posting,
CARF
CARF
RE: Hygienic 3-way control valve required
You can also check Saunder's multiport valves.
http://w
Novaseptic is also a good manufacturer of sanitary valves.
http://www.novaseptic.com/
If you go for nonmetallic valves then GEMU is a good manufacturer.
I also found some very robust looking hygienic valves from GEA Tuchenhagen. Please follow the PDFs on this link:
http://w
CARF
www.carf-engineering.com
