Tools->"Options" not showing up??
I have had several cases where I have been working on a part or assembly and needed to change somthing under the "options" menu. The "options" link in the tools menu is not there. I have made sure the current command was closed and I am still having this happen. I can close the part and then re-open and the options menu is available. Is this normal?
SP 1.1
Tim
SP 1.1
Tim
RE: Tools->"Options" not showing up??
You may have to do this in part and assembly mode.
Best Regards,
Heckler
Sr. Mechanical Engineer
SW2005 SP 2.0 & Pro/E 2001
Dell Precision 370
P4 3.6 GHz, 1GB RAM
XP Pro SP2.0
NIVIDA Quadro FX 1400
Do you trust your intuition or go with the flow?
Has anybody seen this?
Just a thought..........
Macduff
Meggitt Airdynamics Inc.
Senior Designer/Checker
Dell Precision 370
SW2005 Pro SP 1.1
XP Pro SP2.0
NIVIDA Quadro FX 1300
I had the same problem on one of the beta releases for 2005, submitted the problem and it was fixed in the next beta, but it re-appeared in the released version.
