print 1:1 for model
print 1:1 for model
print 1:1 for model
How is this possible, mtd allowed the user to window the area, I can not seem to select an area to print 1:1
RE: print 1:1 for model
If you are trying to print the model (and NOT the drawing) just zoom in to the area you want to print.  In the Print dialog, go into Print Setup and set the Scale to 100% to get 1:1
Drawings have a different method.
Make a dwg with the view 1:1 (or 1/1), shade it, then print.
Chris
Sr. Mechanical Designer, CAD
SolidWorks 05 SP1.1 / PDMWorks 05
ctopher's home site
My model is of a large enclosure and printing from the model is all I would like to do, the print is scaled 1:1 but the area is central,
I'd rather avoid creating drawings and views
