Extracting Assembly Feature Data Through API
Does anyone know how to extract assembly feature data? For example, say I have a part that is just a cylinder. I then add this part to an assembly. In the assembly, I then put a hole through the cylinder. When I attempt to extract the geometry, I do not get that there is a hole there, but if the hole were placed in the part, I would get it. Does anyone know why this is and what can be done about it?
Thanks for any help you can give!
RE: Extracting Assembly Feature Data Through API
To pass that hole down to the part, select to MAKE NEW NAMES in the assmebly feature dialoge box.
You will now have a generic and instance of the part with and without the cut feature.
There are other ways to do want you need.
Steve
http://www.sprdesign.com
http://www.3dlogix.com
-Hora
I made your exercice as you: an assembly with 3 planes and a coordinate system, then I added a cube and I made an assembly cut.
There are 6 features in total, including the cube (ProToolkit counts the component as a feature)
I started my program to read all the features in the current assembly and I got the following answer:
Processing feature 1 of 5, with ID 1, type: 923
Processing feature 2 of 5, with ID 3, type: 923
Processing feature 3 of 5, with ID 5, type: 923
Processing feature 4 of 5, with ID 7, type: 979
Processing feature 5 of 5, with ID 54, type: 916
The solid is ignored by a filter function. Indeed my assembly cut is counted, feature 5, ID=54, feature type = 916
the 923 type means datum plane and the 979 means coordinate system. Then 916 must be the cut.
Then, the program will scan all components of the assemby and I recieved the following info:
Processing feature 1 of 6, with ID 1, type: 923
Processing feature 2 of 6, with ID 3, type: 923
Processing feature 3 of 6, with ID 5, type: 923
Processing feature 4 of 6, with ID 7, type: 979
Processing feature 5 of 6, with ID 55, type: 917
Processing feature 6 of 6, with ID 1107296256, type: 947
Indded, my part has 3 datum planes (923), a coordinate system (979) and a protusion (917).
As you can see, the assemby cut (last feature) is counted here too, but has a type = 947. I did't put a filter here to skip the innactive features or assembly cuts.
The 917 type means PRO_FEAT_PROTUSION
Now if you look in the profeattype.h, you'll find the following info:
#define PRO_FEAT_CUT 916
and
#define PRO_FEAT_ASSEM_CUT 947
To obtain these numbers I used the function:
ProFeatureTypeGet(&feature[i], &featureType);
Probably you have an error in your code. Check it again.
Good luck,
-Hora
Could I see what you did to find out where I'm going wrong? You can just post the relevant stuff. I don't need a whole program. I've been unable to find what I'm doing wrong.
Thanks for the help!
Basicaly, you must call a routine to collect all features from the model (assy or part). Something like this:
MyFeaturesCollect(model, &feature)
In this routine you must call the API function to
visit the model features (ProSolidFeatVisit).
Attention if you have an assembly. You must call it
for a recursive checking.
Then you must get the number of features found:
ProArraySizeGet(feature, &totalFeatures);
And then you can check the tpe of each feature:
for (i=0; i<totalFeatures; i++)
Of course, you can do it in the same time as you collect the features. Is up to you.
Good luck.
-Hora
void MainFunction()
// Show message
ProError error;
error = ProMessageDisplay(UserMsg, "USER %0s", "User click 2");
ProMessageClear();
// Get the current mode
ProMode mode;
error = ProModeCurrentGet(&mode);
if(mode != PRO_MODE_ASSEMBLY)
//Write a message using a "Popup dialog"
ProUIMessageButton *buttons;
ProUIMessageButton user_choice;
ProArrayAlloc(1, sizeof (ProUIMessageButton), 1, (ProArray*)&buttons);
buttons [0] = PRO_UI_MESSAGE_OK;
ProUIMessageDialogDisplay( PROUIMESSAGE_INFO, L"Solid",
L"There is no assembly here!",
buttons, PRO_UI_MESSAGE_OK, &user_choice);
ProArrayFree((ProArray*)&buttons);
return;
// Get the current assembly
ProMdl asmm;
ProMdlCurrentGet(&asmm);
// Get data of the current assembly and print them
char assemblyname[PRO_NAME_SIZE];
char type[PRO_TYPE_SIZE];
ProMdldata mdldata;
ProMdlDataGet(asmm, &mdldata);
ProWstringToString(assemblyname, mdldata.name);
ProWstringToString(type, mdldata.type);
// Open the file
char filename[PRO_NAME_SIZE];
FILE *fp;
strcpy(filename, FILENAMEASSMBLY);
fp = fopen(filename, "w");
// Print name and type of the assembly
fprintf(fp, "The name of the assembly is: %s(%s)\n\n", assemblyname, type);
// Initialise global user-defined data
UserGitemdata appdata;
appdata.fp = fp;
appdata.mdlcount = 0;
appdata.p_compmdls = NULL;
appdata.srfcount = 0;
appdata.p_surfaces = NULL;
appdata.level = 0;
ProGeomitem *psrf;
error = ProArrayAlloc(0, sizeof(ProGeomitem), 1, (ProArray*)&psrf);
appdata.p_surfaces = psrf;
ProMdl *pcompmdl;
error = ProArrayAlloc(0, sizeof(ProMdl), 1, (ProArray*)&pcompmdl);
appdata.p_compmdls = pcompmdl;
// List the assembly members
error = ProSolidFeatVisit((ProSolid)asmm, VisitAsmCompAction,
FilterAsmCompAction, &appdata);
FUNCTION: FilterAsmCompAction()
PURPOSE: A filter used by ProSolidFeatVisit() of func2() to visit features
that are assembly components
ProError FilterAsmCompAction(ProFeature *feature, ProAppData app_data)
// Get type of the feature(only select assembly component)
ProError status;
ProFeattype ftype;
status = ProFeatureTypeGet(feature, &ftype);
if (ftype != PRO_FEAT_COMPONENT)
return(PRO_TK_CONTINUE);
// Get visibility of the feature
ProBoolean visible;
status = ProFeatureVisibilityGet(feature, &visible);
if(status == PRO_TK_NO_ERROR)
if(visible == PRO_B_FALSE)
// If the feature is not active, skip it
ProFeatStatus fstatus;
status = ProFeatureStatusGet(feature, &fstatus);
if(fstatus != PRO_FEAT_ACTIVE)
return(PRO_TK_NO_ERROR);
FUNCTION: VisitAsmCompAction()
PURPOSE: Write the information to the file.
ProError VisitAsmCompAction(ProFeature *feature, ProError status,
ProAppData appdata)
// Initialise use-defined data
ProError error;
FILE *fp;
ProMdl **mdlarrary;
UserGitemdata *appd;
appd = (UserGitemdata *)appdata;
fp = appd->fp;
mdlarrary = &(appd->p_compmdls);
// Get the model and solid of the assembly component
error = ProAsmcompMdlGet(feature, &(appd->mdl));
ProMdl mdl;
error = ProAsmcompMdlGet(feature, &mdl);
ProMdlType type;
ProName name;
ProSolid solid;
error = ProMdlTypeGet((ProMdl)mdl, &type);
error = ProMdlNameGet((ProMdl)mdl, name);
error = ProSolidInit(name, (ProType)type, &solid);
// Get names and typies of the assembly component
ProMdldata mdldata;
char mname[PRO_NAME_SIZE];
char mtype[PRO_TYPE_SIZE];
error = ProMdlDataGet(mdl, &mdldata);
ProWstringToString(mname, mdldata.name);
ProWstringToString(mtype, mdldata.type);
if(strncmp(mtype, "ASM", 3) == 0)
//ProSolidFeatVisit((ProSolid)mdl, user_action, UserAsmCompFilter, &subappd);
else if(strncmp(mtype, "PRT", 3) == 0)
// Add part component to arrary
fprintf(fp, "This is a part component here!\n");
error = ProArrayObjectAdd((ProArray*)mdlarrary, -1, 1, &mdl);
(appd->mdlcount)++;
// Visit all the surfaces of the model
fprintf(fp, "This is a component of assembly!\n");
error = ProSolidSurfaceVisit((ProSolid)mdl,
(ProSurfaceVisitAction)SrfVisitAction,
(ProSurfaceFilterAction)SrfFilterAction,
appdata);
fprintf(fp, "\n\n");
// Return error
if (feature != NULL)
// Return correctly
FUNCTION:
PURPOSE:
ProError SrfFilterAction(ProSurface p_surface, ProAppData app_data)
FUNCTION:
PURPOSE:
ProError SrfVisitAction(ProSurface p_surface, ProError status,
ProError error;
appd = (UserGitemdata*)app_data;
FILE *fp;
fp = appd->fp;
ProGeomitem **srfarray;
srfarray = &(appd->p_surfaces);
// Convert the surface to geometry
ProGeomitem geomitem;
error = ProSurfaceToGeomitem((ProSolid)(appd->mdl), p_surface, &geomitem);
ProFeature feature;
error = ProGeomitemFeatureGet(&geomitem, &feature);
ProSolid owner;
error = ProFeatureSolidGet(&feature, &owner);
// Add surface to array
fprintf(fp, "This is a surface here!\n");
error = ProArrayObjectAdd((ProArray*)srfarray, -1, 1, &geomitem);
(appd->srfcount)++;
// Get the tessellation of the surface
int n_verts, n_facets, (*findices)[3];
double (*fverts)[3], (*fnorms)[3];
int srf_id = 0;
error = ProSurfaceIdGet(p_surface, &srf_id);
ProName mdlName;
ProMdlNameGet(owner,mdlName);
int rev = prodb_surface_tessellation((Prohandle)(owner), srf_id, 0.5, 0.5,
NULL, &n_verts, &fverts, &fnorms, NULL,
&n_facets, &findices);
// Return correctly
Try to use NULL for the first parameter.
-Hora.
Try to apply the same function to each component rather to your assembly. I think this is why your routine crash.
Good luck.
-Hora
