Draining Condensate from Return-side Duct
Hello, we've got an air cooler that consists of a cold water coil and a blower. The only place we can locate the coil is upstream (return, or suction side) of the fan, so I'm a bit concerned about corrosion if condensation droplets reach the fan. But my first concern is draining the condensate from the ductwork at the coil - what kind a trap would allow the condensate to drain out against the negative pressure differential? Thanks for any ideas.
Fran McConville
author of the Pilot Plant Real Book
www.pprbook.com
RE: Draining Condensate from Return-side Duct
If you maintain a coil face velocity below 500fpm, moisture carryover is minimum.
HVAC68
Fran McConville
www.pprbook.com
You can use 2 to 3" difference for a seal.
Fran McConville
www.pprbook.com
If you have about 24" between the condensate drain and the fan, that will be 0.067 in in pressure drop.
Fran McConville
www.pprbook.com
Now, when the damper is closed, the air handler shouldn't be working. Additionally, if the damper is closed because of a fire, what importance may have a few drops of water into the AC ductwork anyhow? I don't think you should desing the P-trap for that condition.
PS: Regarding pressure drops, CFM and duct sizing, get yourself a ductulator from Trane or other manufacturer. Call your Trane dealer, they will probably give it to you for free, or charge like 5 or 6 bucks.
