FLoWorks help
FLoWorks help
I need some help with COSMOS FLoWorks. I'm doing external flow analysis with questionable results. FLoWorks is showing a drag force of 2 lbs on an object I know has around 70 lbs. When I show flow trajectories they flow thru the body and not around. It's like the body does not exist. It's not the component control because all bodies are enabled. Help please. Thanks.
RE: FLoWorks help
Hope this helps.. -Matt
RE: FLoWorks help
RE: FLoWorks help
RE: FLoWorks help
RE: FLoWorks help
If you have a thin model, you may need to refine your mesh. Go to your local initial mesh settings. There are 4 tabs, click the help button on each to learn what each option will do for you. If you still can't get it to work with these settings you may need to look into "control planes" in the help menu.
-Matt
RE: FLoWorks help
RE: FLoWorks help
RE: FLoWorks help
