Is there a plastic composite material that can do this?
hello plastics proffessionals,
I am seeking a recommendation for a plastic or composite material that possesses the following properties for my newest project...preferably moldable through injection processes but not required:
low thermal conductivity...specifically resistance to cold (the component will be exposed to 40 ms bursts of cryogen for 1 hz for hundreds of cycles)high priority
low optical energy absorbtion mostly visible spectrum 595 - 800nm (ie transparent or white colored?)
stiff but not brittle, will be an abused device...
flameproof or self extingishing
FDA approved for medical applications (non invasive though)
acid and solvent resistance
resistant to (optically heated) burned on material surface degradation from burned skin and hair (as slick a surface as best can be achieved)second highest priority
Thanks gentlemen and gentlewomen
photon450
RE: Is there a plastic composite material that can do this?
Suggestions might be PEEK or PES.
Thanks..... I'll start investigating those.
photon450
