Weld C6x8.2 perpendicular to TS6x3x3/8
I would like your opinion regarding the potential impact of welding a C6 perpendicular to a tube steel member (C6x8.2 - TS6x3x3/8), the 6" dimensions match up. Assuming an equivalent weld size of 3/16" on both flanges and the web a direct weldment qualifies. One specific is that the weld on the top flange must be flush with the two members; this eliminates a plate that extends above the TS/C6. A flare bevel weld on both flanges results in an effective throat of more than 3/16" (5/8 x (t=.375) = .23" (per AWS D1.1, figure 3.3).
Even with an interstial plate between the channel and the tube wall the effective throat would be the same and adequate. I performed a rough check on the punching shear of the tube's wall using criteria in the AWS D1.1 and it checks out OK.
Does anyone have any anecdotal comments regarding similar joint configurations? One concern that I have is that the radius on the tube corner can range from less than the thickness of the wall to as much as three times the thickness, therby increasing the gap between flange and tube.
I would appreciate hearing from you, thanks in advance :>)
RE: Weld C6x8.2 perpendicular to TS6x3x3/8
One thing is you may get some weld distortion that will tend to curve the piece toward the channel side.
One thing to watch is that the outside radius of the tube can vary with manufacturer, which changes your weld geometry.
If the C6 is only carrying shear, you need not to weld the flanges. Fillet welds on both sides of the web will do.
Lutfi
www.cdeco.com
"the weld on the top flange must be flush with the two members"
Those two lines made me think the channel was beside the tube, which is why I asked.
DaveAtkins
I have checked the stresses in the tube wall through use of the procedure in the AWS D1.1 for punching shear. Stresses are reasonably low. What my concern is are there any other issues (that I have not addressed in my initial post) that would negatively impact the joint connection.
What I mean to say is that I don't know what I don't (but should) know. :>)
