Need Clarity on runout issue
I have a tolerance on a motor shaft that needs clarity:
the dim is now as follows: (metric)
single-arrow runout: "0.0381"
position referenced to the housing boss: "Dia 0.0381"
Does the positional tolerance restrict the runout to be within a 'cylinder' of Dia 0.0381 along the entire length?
RE: Need Clarity on runout issue
Best Regards,
Heckler
Do you trust your intuition or go with the flow?
Also, with a motor shaft, it would be spinning. Wouldn't total runout be more appropriate? I'm not sure without seeing the part.
Chris
Sr. Mechanical Designer, CAD
SolidWorks 05 SP1.1 / PDMWorks 05
ctopher's home site
Macduff
Meggitt Airdynamics Inc.
Senior Designer/Checker
Dell Precision 370
SW2005 Pro SP 1.1
XP Pro SP2.0
NIVIDA Quadro FX 1300
Total runout would make for an extremely costly shaft. I've seen pump shafts with multiple bearing and element diamters having runouts of .0005" to grind centers. If this was total runout it would mean that the entire surface would have to fall within this tolerance band.
I think Kim needs to give us more information to correctly answer her inquiry.
Best Regards,
Heckler
Sr. Mechanical Engineer
SW2005 SP 2.0 & Pro/E 2001
Dell Precision 370
P4 3.6 GHz, 1GB RAM
XP Pro SP2.0
NIVIDA Quadro FX 1400
Chris
ctopher's home site
