.exp file+catia v4
.exp file+catia v4
I received .exp file & able to download the file from Autoweb but when i tried to put into catia v4 the execution failed.
Could anybody explain me if any solution.
RE: .exp file+catia v4
tools-> utility-> extractmodelfromsequential
If you want to do it with V4, use the CATIMP utility to import the file back into CATIA.
I able to download the xyz.exp (its catia v4 data) from Autoweb but received message below while trying to put data into catia v4
"xyz.exp is a directory (not copied)" & hence the execution failed.
Thanking you in advance,
