VB/VC source code
VB/VC source code
I need a source code in VB or VC or both to light a LED through the parrallel port. Can Some body help me??.
Rohith
Rohith
RE: VB/VC source code
If you can read French you will find two sources code on a French visual basic forum :
http://www.vbfrance.com/article.aspx?ID=9583
and
http://www.vbfrance.com/code.aspx?ID=8166
regards,
It should get you started.
Pat
Good Luck
johnwm
________________________________________________________
To get the best from these forums read FAQ731-376 before posting
UK steam enthusiasts: www.essexsteam.co.uk
