PM of cables and cable trays
Hi
We want to start the PM of cables and cable trays at our plant. We will check the following items in the course
1. Physical inspection of cables and cable trays.
2. Look for sharp edges along the bents of cable tray.
3. Check the ground connection integrity.
Can you please identify some more things that should be checked during this activity.
RE: PM of cables and cable trays
Trays:
1)Inspect accessible components for cleanliness, mechanical, and electrical integrity, and for presence of damage or deterioration.
2)Check trays for loose supports and are supported in accordance with NECA/NEMA 105 and Section [16190] [16070] Supporting Devices.
Cables:
1)Inspect cable for physical damage and proper connection.
2)Remove exposed abandoned wire and cable, including abandoned wire and cable above accessible ceiling finishes. Patch surfaces where removed cables pass through building finishes.
3)Disconnect abandoned circuits and remove circuit wire and cable. Remove abandoned boxes when wire and cable servicing boxes is abandoned and removed. Install blank cover for abandoned boxes not removed.
David Baird
mrbaird@hotmail.com
Sr Controls Engineer
EET degree.
Journeyman Electrician.
Do you have any sheilded medium voltage power cables in your cable trays?
