Need info on antenna reflector spacing
I have a 6 element collinear 1365 MHZ. I want to install
a reflector, how do you compute the spacing between the
antenna and reflector?
RE: Need info on antenna reflector spacing
Simple answer would be a bit less than a quarter wavelength (0.2 to 0.25 lambda) or roughly 5 cm (for your frequency).
If you really want some serious gain, use a Corner Reflector.
http://www.guerrilla.net/reference/antennas/2ghz_collinear_omni
http://www.guerrilla.net/reference/antennas/2ghz_collinear_omni_lowpwr/
http://www.rason.org/Projects/collant/collant.htm
http://www.repeater-builder.com/rbtip/wa6svt.html
http://www.indiamart.com/starantenna/collinear-antenna.html
http://www.cushcraft.com/comm/comm_data_sheets/S8243B.pdf
etc. for more info.
