variable for image frame
Hi all! When you insert an image into your drawing, you can control if you want to display the image frame or not with the IMAGEFRAME command. You type imageframe and set it to ON or OFF, simple isn't it?
I'd like to know the NAME of the acad's VARIABLE that stores that information. When you type ON somewhere there must be a variable that sets to 1, and, the same way, when you type OFF that variable sets to 0. Does anyone know the name of that variable?
Thanks a lot
