shotcrete-air entrainment in dry mix and wet mix process
Dear all,
I read an article regarding shotcrete application. In wet mix process, air entrainment is important and may require at least 6% air. However with dry mix process, air may not purposely entrained. What makes the air entrainment be different in the two processes? What are the mechanisms behind it?
Thankx,
Neon
Thankx,
Neon
RE: shotcrete-air entrainment in dry mix and wet mix process
Ciao.
