Viewport Problem
Viewport Problem
I have created a drawing in Model Space that contains dashed lines. When I create a Viewport, with the Model Space contents, the lines all appear and print as solid lines. Under foremat layer, the lines are listed as being dashed. Any help would be appreciated.
RE: Viewport Problem
When printing from model space, your LTSCALE should be set equal to the scale factor of whatever your drawing will be (48 for 1/4"=1', 96 for 1/8"=1', etc.)
Alternatively set your LTSCALE to whatever looks right in modelspace, and set PSLTSCALE to 0. But if you have differently scaled viewports in PS (layout mode) you'll want to use option 1.
