Induction Hydro Generator Control
I am in need of information concerning the starter and power controler for a 300kW 480 VAC indcution generator system.
The generator will be driven by a hydro turbine and directly connected to the power grid once at synchro speed. The power control must would output s 4-20ma signal to turbine valve.
Dan
Dan
RE: Induction Hydro Generator Control
With a little work you could disconnect the start winding contact from the windings and also use that as a control input.
