Residual Amine Testing
Hello
Iam chemical engineer working in fields with chemical company ,we have corrosion inhibitor(water soluble) used for treated The transportation oil line .
My qustion How to measure residual amine from the sample which taken from the last point of the pipe.
N.B
(The quantitiy of water always Trace)
Tanks alot
ELsheikhi.
RE: Residual Amine Testing
Hi elsheiki
There are commercially available online gascromatographs. Unfortunately you will experience an extremely variable composition of the carrier fluid, so I am not sure you can suppress the noise.
Moreover, the slug will probably blind the gaschromatograph in a very short time.
Probably the only way is to autosample and monitor offline, maybe with an automatic system, and cross check with lab every now and then.
