24v Float switches
24v Float switches
24v Float switches
I have numerous Compac Engineering, erecta switches, M/N 10-782 in heated baths that indicate level.  They have been in service for 3-4 years with mild replacement requirements.  However, as of late they are failing at an increasing rate.  The cost of continuing replacement is becoming cost prohibited.  Does anyone have direct access to Compac Engineering for direct purchasing or have anyone a better suggestion of replacement?
GOT FLOATS?
ZRT800
