Coefficient of friction between ABS and Delrin
Can someone tell me the coefficient of friction between abs and delrin? I want something low. I am planning to align an abs part that has a pin into a guide slot made from another plastic. If delrin is not suitalbe, is there another common, low cost injection moldable plastic that would be suitable?
Kyle
Kyle
RE: Coefficient of friction between ABS and Delrin
"The ideal client is one possessed of great good sense and perfect judgement;
that is to say, one who agrees entirely with the designer at all times and in every respect."
Fenwick Williams, Naval Architect.
PE in its various forms has been called the poor man's teflon. May lack rigidity.
Nylon is pretty good. Pat Primmer is the man to advise for this material.
Kyle
As LNP has already been mentioned, I did not comment further.
A lot depends on the actual conditions of use. Nylons, polyesters, acetals, various fluorocarbons, PE and PP all make good bearings and all have strengths and weaknesses.
RTP Company also has an excellent web site for data.
http://www.rtpcompany.com/
