Properties in templates...like text size, line font etc...
Ok...likley anther dumb ass question...but I keep doing things correctly by accident.
I'm trying to set my text size and line font and units  etc to remain the way I want. So I set them and I try to save my drawing template with these settings. But it's not keeping them. Somehow, I managed to get it to keep my units as inches instead of SI, but that's all.  I can't figure out what I did to correct my units...
RE: Properties in templates...like text size, line font etc...
Read help on creating templates and saving the sheet format, etc.
Chris
Sr. Mechanical Designer, CAD
SolidWorks 05 SP1.1 / PDMWorks 05
ctopher's home site
go to File- "Save Sheet Format..."
That save your font sizes, etc to a .slddrt file which is used to reload a sheet.
Best Regards,
Jon
Challenges are what makes life interesting; overcoming them is what makes life meaningful.
Solidworks 2005 SP2.0
I believe I just noticed something important. I drawing template and sheet format it turns out are NOT the same thing!
Very good! They are not and as soon as people understand that, they will understand how to use them to their advantage.
Regards.
Scott Baugh, CSWP
3DVision Technologies
www.3dvisiontech.com
www.scottjbaugh.com
FAQ731-376
FAQ559-716 - SW Fora Users
Yeah both of them are different ! To save your font etc settings-- after you save the sheet format, save the blank drawing document also and close it. You can delete it later. That way it remembers the settings from your format. Sometimes I didnt have to do that ..I just had to save the sheet format ..but sometimes I have found this work. So give it a shot!
Mechanical Engineer
