Temp Adhesives for Traffic Reflectors
I'm working on a project in SW Washington state. We just finished a new bridge and will be switching traffic onto it this summer. The problem I have is that the traffic switch puts both directions of I-5 on the bridge for this next stage of construction. This is only temporary and is not the permanent configuration. We don't want to paint the lane lines on the new bridge deck as that would force us to either grind or sandblast the paint off later. I was thinking about glueing reflectors to the deck but need some kind of adhesive that can be removed fairly easily later on without marring the finish surface. Any ideas?
RE: Temp Adhesives for Traffic Reflectors
We have used 3M Wet Reflective Removable tape for situations where a temporary marking is needed. If it is put down in dry weather and doesn't have traffic tracking across it it has performed well.
Our only attempt to use raised markers as a temporary marking failed because traffic crossing over the RPMs when changing lanes crushed the markers.
