Animating SheetMetal
Has anyone found a way to make an animation of a sheetmetal part opening and closing? thanks
Chris
Sr. Mechanical Designer, CAD
SolidWorks 05 SP1.1 / PDMWorks 05
ctopher's home site
RE: Animating SheetMetal
Do you mean an animation of flattening & unflattening the part?
Making the best use of this Forum.  FAQ559-716
How to get answers to your SW questions.  FAQ559-1091
Helpful SW websites every user should be aware of.  FAQ559-520
yes, sorry that is what I meant ... it's Friday
Chris
ctopher's home site
OK ... quick answer is yes ... using the Screen Capture
I just did a test, but using Windows Media Player, it played the AVI so fast you could hardly see it.
I remember a year or more back someone posted a short video of a sheet metal part in  a post here, but no idea what it was about, so cannot search.
Hopefully someone else may remember or know of a better way to do what you want.
I did the same and can not slow it down.
I thought I have seen it before also, but wasn't sure.
Chris
ctopher's home site
I've had success in the past by taking screen captures of the various stages of forming, turning them into GIFs, then used a freeware (from MicroSoft I think) to convert the GIFs into an animated GIF.  It took some time, but it worked.
"I think there is a world market for maybe five computers."
Thomas Watson, chairman of IBM, 1943.
Have you read FAQ731-376 to make the best use of Eng-Tips Forums?
Mike J Wilson's site had some animations that could have helped, but it seems his site was hijacked by Autodesk:
http://www.mikejwilson.com/
If it is a simple part, then you can "Save as JPEG".  But if it is an assembly, such as the sheetmetal between the die and punch being formed, then make configurations of the different degrees of the bend stages, and save each configuration as a jpeg.
Flores
Hmmm ... methinks Mike will not be impressed
There is a better way to do this.  Create a design table to drive the bend angles, arranged sequentially by name so that they will sort in the order you want the part to bend in the animation.  The bend angles should change by a small increment in each configuration so that the animation comes out smooth.  Then, turn on screen capture and use a macro to iterate through all the configurations.  Then just turn off screen capture once the forming is done.  By using a macro you can have many configurations but you don't have to manually switch from one to the next.
There is an example of rebuilding configurations in the api help.  I added a pause loop to also slow down the bending.  You can find the best combination of bend angle change per configuration / PauseTime to get a smooth animation at the desired file size.  Change PauseTime to suit your taste.  Paste this into a new macro and you can create these animations in 5 minutes with no hassle
Enjoy...
_______________________________________________________
Option Explicit
Sub main()
    Dim swApp                   As SldWorks.SldWorks
    Dim swModel                 As SldWorks.ModelDoc2
    Dim vConfNameArr            As Variant
    Dim sConfigName             As String
    Dim i                       As Long
    Dim bShowConfig             As Boolean
    Dim bRebuild                As Boolean
    Dim StartTime, PauseTime As Single
    PauseTime = 0.5
    Set swApp = CreateObject("SldWorks.Application")
    Set swModel = swApp.ActiveDoc
    vConfNameArr = swModel.GetConfigurationNames
    For i = 0 To UBound(vConfNameArr)
        sConfigName = vConfNameArr(i)
        bShowConfig = swModel.ShowConfiguration2(sConfigName)
        bRebuild = swModel.ForceRebuild3(False)
        StartTime = Timer    ' Set start time.
        Do While Timer < StartTime + PauseTime
            DoEvents    ' Yield to other processes.
        Loop
    Next i
End Sub
Thanks guys.
CBL, I will check it out. I think I had an old version before. I will update it.
Stoker, thanks I'll try it.
Chris
ctopher's home site
If you create an Unfold of all the bends & then create an individual Fold for each bend, you can then roll back to the Unfold & do a screen capture AVI while rolling forward through the Folds in sequence.
