split function - setting for auto no-show of original element?
When I use the split function to trim curves or surfaces, a copy of the original element is made. It doesn't go into no-show; I have to put it there or delete it. Is there some setting in the system options that will cause original elements to go into no-show?
RE: split function - setting for auto no-show of original element?
You are probably doing something that forces elements to show up in more than one place on the tree. That would explain your hide problem.
