save a perspective JPEG
Hi
I set up a part or assembly on screen as a perspective view.
When I go to the Save a Copy to export it as a high res JPG, the view clicks back to the default iso view.
Any way around this issue?
valveman47
valveman47
RE: save a perspective JPEG
Best Regards,
Heckler
Do you trust your intuition or go with the flow?
2001
The intention is to save a hi-res jpeg of a perspective view of the the part.
valveman47
Where do I look for that?
The trick is to
Open Save A Copy.. dialogue box first
then
View | Model Setup | Perspective
then save the file at the resolution you want.
Thanks anyway.
