PUMPS FOR PAINT WATER BASE
COULD YOU TELL ME ABOUT WHAT MATERIALS I NEED TO USE IN ORDER TO PUMP A PAINT WATER BASE? I DONT KNOW HOW ABRASIVE IT´S.
TYPE OF PUMP: VANE PUMP A 495 RPM
SOLIDS :15%
VISCOSITY: 2000 mPa.s
flow: 30 m3/h
density: 1.1 Kg/dm3
Tª: 20ºc
PH :NEUTRO.
I THINK THAT I SHOULD USE :
CASING, HEADS : NI-RESIST-2
VANES: POLYMER
ROTOR: NI RESIST
SHAFT : HIGH STRENGTH STEEL.
MECHANICAL SEALS :
VITON, SILICON CARBIDE
ITS POSSIBLE TO USE CAST IRON CASING AND HEADS?
THANKS.
SOLIDS :15%
flow: 30 m3/h
density: 1.1 Kg/dm3
Tª: 20ºc
PH :NEUTRO.
VANES: POLYMER
ROTOR: NI RESIST
MECHANICAL SEALS :
THANKS.
RE: PUMPS FOR PAINT WATER BASE
The corrosion resistance issues are probably linked to duty cycle. All that i can tell you is that some water based paints tend to be fairly corrosive and all of the paint lines that I have seen are 100% stainless.
Corrosion never sleeps, but it can be managed.
http://www.trenttube.com/Trent/tech_form.htm
