It won't prompt me for draawing template
I've already gone to TOOLS>OPTIONS>SYSTEM OPTIONS>DRAWING TEMPLATES. The "Prompt User..." selection is checked. If I click on the "..." button to search for another template, it doesn't go to a file "explorer". It just pops up with the preview for the default template (as if I had just selected FILE>NEW>DRAW)
What the hell?? I never had this trouble with SW04
RE: It won't prompt me for draawing template
Scott Baugh, CSWP
3DVision Technologies
www.3dvisiontech.com
www.scottjbaugh.com
FAQ731-376
FAQ559-716 - SW Fora Users
Making the best use of this Forum. FAQ559-716
How to get answers to your SW questions. FAQ559-1091
Helpful SW websites every user should be aware of. FAQ559-520
Scott Baugh, CSWP
www.scottjbaugh.com
FAQ731-376
Chris
Sr. Mechanical Designer, CAD
SolidWorks 05 SP1.1 / PDMWorks 05
ctopher's home site
Next time you open that C-Size Template you will have a C-size Sheet format.
Scott Baugh, CSWP
www.scottjbaugh.com
FAQ731-376
Then close, re-open.
Then go to FILE-OPTIONS-SYSTEM OPTIONS-DEFAULT TEMPLATES. Browse to all of your templates.
Chris
ctopher's home site
It should work.
Or try doing the setup above, but do not check prompt user.
Chris
ctopher's home site
I think there is some confusion here because of the different replies in this thread and your answers to each of them.
Is this what your wanting to see happen with your Drawing files when you open them?
http://ww
Please let us know Specifically what you want to happen.
Scott Baugh, CSWP
www.scottjbaugh.com
FAQ731-376
If someone has found a way to do this on all their custom Templates, then please enlighten me or us, because it's been like this for yearssss!
Scott Baugh, CSWP
www.scottjbaugh.com
FAQ731-376
But now, the sheet format that comes up IS the "stock" A-size Solidworks template. I have to do my little work-around to get to MY custom template.....which BTW won't retain any of my selected options, like units and precision ...but that's another thread
I'm sorry if I'm being obtuse...but I never touched any of the original dwg templates.....
C:\Program Files\SolidWorks\data\templates\Drawing.drwdot
then to the right of that field, it has the "..." button. It will not let me change this text (manually) at all, and the "..." button doesn't do anything.
Scott Baugh, CSWP
www.scottjbaugh.com
FAQ731-376
I had done this:
CorBlimeyLimey (Mechanical) 1 Apr 05 9:25
Did you change the Tools > Options > File Locations in SW04? Have you re-done that in SW05?
BUT I didn;t delete the old ones out of the list. Now it seems to work.
Thanks all for your patience!
(and how did this thread earn a star?)
Have a good weekend.
Chris
ctopher's home site
1) giving the correct answer.
2) spending his valuable time to make the screen capture video to clarify the problem.
Stars are given by members who want to say "Thankyou" for the good tips & help they receive from the posts. (see bottom left corner of each post ... "Thank ???? for this valuable post"
"YOu're idea is stupid!"
"No YOU'RE stupid!!"
etc etc...
And it's a mountain biking forum...
