Animation in top level using sub-assy?
Good morning everyone!
I'm in the process of putting together a large cabinet assembly that holds two pumps.  Eventually, I'd like to make animations showing the doors of the cabinet opening to reveal the working pumps.
To start, I've put together the assembly, complete with the two doors and a hinge assembly that I got from the SW website.  There are 4 of those hinge sub-assemblies in my assembly.
The question I'd like to pose right now, since I'm not ready to start making animations yet, is this:
Will I be able to create that animation in the future if the hinge is actually a 2-part sub-assy.  OR, will it be necessary to mate the two parts of the hinge in my top level assembly to create the animation?
Appreciate the input.
RE: Animation in top level using sub-assy?
If you have the mates set up correctly and you can move it in the main assembly the way you want it to work then you can make it work as an animation.
Scott Baugh, CSWP
3DVision Technologies
www.3dvisiontech.com
www.scottjbaugh.com
FAQ731-376
FAQ559-716 - SW Fora Users
Also you will have to have the sub-assemblies set to Felxible
Making the best use of this Forum.  FAQ559-716
How to get answers to your SW questions.  FAQ559-1091
Helpful SW websites every user should be aware of.  FAQ559-520
Thankyou!  Flexible sub-assy's is exactly what I was looking for!
MimiN63,
Another feature that may be helpful to you is using Limit Mates. In your case you can specify a min and max angle that you want the doors to open.
It also makes doing your animation much easier, because you won't accidentally move the door through the cabinet.
Best Regards,
Jon
Challenges are what makes life interesting; overcoming them is what makes life meaningful.
Solidworks 2005 SP2.0
