Leftover insulation
Leftover insulation
Good morning!
We fabricate insulation parts, and have a specific part that is made from 1/2", 3# Microlite (J.M. material). We have a leftover circle, which measures a perfect 4" diameter, and we have literally thousands per month left over. Can any of you think of a way these can be used, or by whom?
I just can't bear the thought of another 2-3 dumpster-loads of perfectly cut little parts.
Thanks!
Thanks!
RE: Leftover insulation
TTFN
http://www.in.gov/idem/imx/
I've always plyed with the idea of aquiring some of the used telephone poles which are periodically listed. They would make a great bridge across my ravine.
http://www.advancedwater.com/Filters/filters.htm.
If that doesn't work then go to this web site: http://ww
