MS SQL: duplicates with DISTINCT
SELECT  DISTINCT
LTRIM(RTRIM(queryParam)) AS qpTrimmed
FROM queryParamValTbl
has duplicates (it removes most duplicates)
I assumed that
scngs_zone
scngs_zone
was really
'scngs_zone'
'scngs_zone  '   -- trailing whitespace
So I tried the following:
SELECT
DISTINCT
INTO #rTmp
ORDER BY qpTrimmed
SELECT  DISTINCT    * FROM #rTmp
-- But it has the exact same duplicates
Note, most duplicates are removed.
SQL 2000 & Win03 - lastest updates on each
RE: MS SQL: duplicates with DISTINCT
It seems the server excutes DISTINCT before the trimminng. I'm not using MS SQL but I do know it has the feature to work with temporary tables (which is a nice feature). So I'll create a temporary table with the trimmed values and I'll make a SELECT DISTINCT on it.
Nope. I figured out the problem is:
RTRIM
Returns a character string after truncating all trailing blanks.
But I don't have blanks, I have '\r\n'
apparently there is no T-SQL function to remove white space.
T-SQL deals with ASCII strings, and shouldn't be expected to translate arbitrary character sequences that may represent white space in some other languages.
Good Luck
johnwm
________________________________________________________
To get the best from these forums read FAQ731-376 before posting
UK steam enthusiasts: www.essexsteam.co.uk
I suppose you could argue that, but SQL also lets you specify the language you are using. That same arguement applies double to Java, C#, C++ etc, yet their Trim functions remove whitespace of the character set installed.
It's such a common problem every high level language has the Trim methods to deal with it. Here is how I solved the problem.
CREATE FUNCTION xTRIM  (@rVarParam VARCHAR(1024))
RETURNS VARCHAR(1024)
AS
BEGIN
    RETURN LTRIM(RTRIM(
    REPLACE(REPLACE(@rVarParam,CHAR(10),''),CHAR(13),'')
END
Then changed my Query to:
SELECT  DISTINCT   dbo.xTRIM(queryParam)
WHERE queryParamValue
    NOT IN (  SELECT queryName     FROM queryNameTbl)
Yes, and unicode too. See nvarchar
